Been chasing Lean code Bank 1 and 2, now other problems
For the past 2 weeks I have been chasing correcting things for Bank 1 and 2 lean codes. New valve cover gaskets (which were needed) remanufactured injectors (dirty and need new seals) new hoses for the purge valve, new part load hose. cleaned the MAF, and new gaskets for the intake. while the intake was off took advantage of replacing the hard to get coolong hose took the VDP out for a run after clearing codes, the Restricted Performance flashed on but went back off within about 5 seconds, but the the check engine light stayed on.
went back home and parked in the garage and let the car sit for a bit, went down to start the car and got the dash lighting up all sorts of things. well 3 I have written down . the following is what I wrote down: Trac Con not available, Fail Safe Engine Mode, and ACS not Available. I may have missed one I believe something with the trans but will have to recheck on that. Also had a Low Coolant (which I topped off) but have notice I lost coolant on the floor and looks like some into the engine bay (so clean up time) then check to see what is what. And 2 new codes on the reader P1121 Throttle Position Sensor inconsistent with MAF/MAP, and B1121 Driver Fan Feedback Circuit resistance low
A bit winded on this subject. I am hoping that maybe, and just maybe I overlooked a hose clamp and by change did not get it on right and the coolant sprayed some of the components.![Icon Werd](https://www.jaguarforums.com/forum/images/smilies/icon_werd.gif)
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
see page 36 http://jagrepair.com/images/AutoRepa..._2001_OBD2.pdf
P1121 seems to be a failure in the pedal position sensor, or associated wiring. It's got two pots to measure position (like in the TB) and if the readings don't agree it throws this code.
daverb (06-06-2017)
With the work already carried out (new seals) then a MAF clean/replace could sort the lean codes on both banks, Stu1986 switched MAF sensors and that has seemed to cure his lean on both banks codes, do a search of his recent 'chasing lean codes' thread.
The first lot like ABS Trac etc sounds like a dying battery, these cars don't like a voltage drop, anything lower than 12.5V and they start to get ghosts in the machine, you'll see these warnings on cranking/initial running when the battery isn't fit enough.
Either stick the battery on charge, or replace.
I battled a P1121 which led to a throttle rebuild, on the AJ27 throttle the tracks wear in the TPPS/TPS leading to a fault posting which lead to random failsafes.
Well, went down to the garage and took another look, for most of the codes was an easy fix and was something I thought of checking first. Seems that when I changed the coolant, I did not get it bleed out complete and some of the fluid got to some connections, cleaned them hard reset, and Abra Ka Dabra, all gone. so that was a cheap and easy fix, and yes made sure I got the system bleed out right this time.
Sean, the battery is new so I know that is good, and I have been following Stu on his mission. Even tho I did replace the intake gaskets, I decided to run another smoke out test, had some smoke coming out from the intake so figure I would just order some new intake gaskets from Jaguar. A bit pricey for 8 but figure worth it, the others were to be OEM quality but guess not lesson learned. also when I replaced the fuel injects somehow put a slight tear in a couple of the large gaskets (don't ask, don't know how) and had a bit of the test smoke come out pass them, they are now replaced
so now to wait for the new gaskets to come in, should be Friday or Saturday and get that done.
shocks, I have them check it out.
