Bent Valve
Hey all! I have a quick question. Will the AJV8 run with a bent valve after the timing system was serviced? I found a Lincoln LS that does run like crap, and I'm thinking they didn't time it right (there are old timing system components in the trunk). I can pick it up for a steal. But I'm also wondering if it could run with a bent valve... because then it might not be worth the purchase if that is the case.
P.S. I would have posted this on a Lincoln forum, but you people on here are awesome! Thanks in advance!
Here is the sound of it running: Lincoln - YouTube
