Best brake pads (for spirited driving) for 2002 XJR
I took my 2002 XJR out for some "spirited" read ***** out performance testing and am quite underwhelmed with the brake fade. Mine does not have the R1 package, but has the same size rotors as my 2002 XJ8.
My 2002 XJ8 outbrakes my R on repeated stopping, so I'm ***-u-ming my R has some underperforming pads on it.
Anybody try EBC red stuff pads? That looks attractive to me right now...
I'm not interested at this time to change to bigger brakes just yet, I would first like to try better pads. The car is not normally going to be subjected to road race conditions, just once in a great while.
Suggestions? Part numbers prices and suggested places of purchase are greatly appreciated![Icon Captain](https://www.jaguarforums.com/forum/images/smilies/icon_captain.gif)
Can anyone tell me the specs for stock rotor thickness? Mine has a bit of a ridge, just wondering if I should replace the rotors too yet?
I can recommend the EBC Redstuff pads. I bought mine online from camskill.co.uk, but you'll probably get a better price somewhere closer to you. I'd also recommend a fluid change to further prevent fading. And check that the brake cooling ducts are still in place... one of mine was missing the flange that holds it in the wheel well.
My memory is saying that the OE pads are made by Jurid -- a big supplier to BMW .... I have a set of rotors and pads in my garage that I'm going to install when I switch to my winter tires in a few months -- so I just looked at them and I think it is Jurid.
The problem I have always found with the "performance" pads: They have bad initial grip when compared to OE ......you need to apply greater force to achieve normally braking performance when they are cold ...... and that is most of the time.
What are the tires like -- normally makes a huge difference. I'm in a hilly area with mine about 6 months of the year and I don't have a fade problem.
With any kind of a ridge -- you are most likely looking at new rotors. Get good ones --- The Jaguar front end is a bit touchy and the rotors supplied from the dealer are a balanced set.
I took off some wheels today and found the front rotors were very worn and the pads were almost gone, so this could explain the poor performance.
I've ordered a set of EBC vented front rotors and EBC red stuff pads all around. I thought I would try this before spending any big money on any bigger upgrades. I will post again when they have been installed and the pads are properly bedded and "tested"
Interesting set you have from the bullet proofed car. I'm going to first try the low dollar upgrade and see how I like it since I rarely step on the brakes hard more than once or twice a minute.
Didn't like the Redstuff at all, they also needed to be hot to work well, so not a good choice if you don't use them too often. When confronting EBC with this, they advised me to use the Yellow Stuff. Never used that but on paper it did show a higher friction coefficient, also at colder temps. Have used Pagids 421 they were great in breaking power.
I finally got around to putting a set of Redstuff pads & new OEM discs on the X-Type, haven't had a chance to really put them to work yet, but I did bed them in with heavy braking from progressively faster speeds, with the last stop from 120kmh down to about 5kmh & i was well impressed. But obviously they were warmed up by then!
The real test will be from 200kmh down to 120kmh, which was my big complaint about the OEM kit (ok they were pretty well worn out) you need good brakes on the German Autobahns...
I went to Redstuff on the recommendation of UK forum members...EBC is from the UK after all. A few have also gone to Yellowstuff but I was under the impression that they were more like trackday pads & would eat up your discs with regular round-town driving. Another reason I went for the Redstuff because they were half the price off ebay in the UK (incl shipping) compared to OEM pads bought locally in Switzerland!
New brakes are new brakes, if your discs & pads are knackered then new OEM parts will still be a big improvement...
Hmmmm. Well they are already on their way so I will try them and post my results.
If I'm not happy with the pads I can try the 421s.
Did you do a full bleed on the brake fluid? Not sure if you know the full history of the vehicle -- it can make a bid difference if it has not been done in a long time.
I think you will find a need for greater brake force required with the red pads -- although ......... do you know what is currently installed?
Yes we did a complete and full bleed with new DOT 4 fluid right after I bought the car a few months ago.
I have no idea what is currently installed but they are way past due to be changed.
I just remembered that you posted that your XJR has low miles -- so it probably still has the original rotors ......
Mine is now at 55k and is ready for new rotors - but I had just the pads replaced at 26k -- The rotors were fine. Normally if I am below 1/2 new I replace the rotors with the pads.
I asked about the fluid because it is so often overlooked -- I don't know how many owners your car has had ... but many times second owners don't perform the fluid changes and they can make a difference.
My track days are few and far between and I'm doing 50's stuff at this point -- so it's downshifting rather than playing with different pads
True,
Too often you see guys with new vipers and corvettes at the track with stock (cheap) DOT3 fluid that boils after only a few hard stops, then no brakes and PACK! into the wall. Happens way too often.
Since I rarely do anything that resembles road racing with my XJR, I am hoping the vented rotors and Red stuff pads will be fine.
Thank you for your input.
Am thinking of getting the Pagid R15 next, they sure look good on paper, just look at the friction range from cold to hot:
‘PAGID RS’ Material Specifications.
http://www.pagid-brake-pads.co.uk/pr...amic-based.php
Update on the red stuff pads.
So far, so good, started out very squeaky... like the "nightingale floor" at Nijo castle in Tokyo..
Now, 100 miles later, they still squeak just a tiny bit some times. Excellent braking power, I'm not noticing any more pedal pressure needed. The brakes give me a sense of confidence that they could handle anything I am likely to throw at them on the street.
I'm not seeing any dust yet. The are rated very low dust. I'm going to test them for at least another 500 miles before I decide to try them on my wife's XJ8.
