Best deal on Oxygen sensors?
Bosch 15627 upstream wide-band A/F sensor, exact fit -- $89.99 at advanceautoparts.com. Bosch 15626 downstream exact fit -- $95.99. Be sure to look at the top of the advanceautoparts.com webpage... often there is a discount code that will get you 10-20% off your order. Free shipping too (No affiliation).
This certainly appears to be the correct part, no? Not exactly cheap, but wayyyyyy better than the $565 each that jag wants for the jag-labeled parts.
Here's my question: Is it worth spending $350 plus labor to replace the o2 sensors? My 1999 XJR with original sensors has 126,000 miles, runs fine, and has no codes. On a 440 mile trip yesterday it showed 19.3 mpg. Average speed from the computer showed 58 mph but it was 430 miles of around 70 mph cruising and 10 miles of in-town driving. Will changing the sensors improve my mileage? By how much? 10%? More? It seems like I used to get in the low 20's back when it was in the 60,000 mile range, but maybe I'm dreaming.
(With the current discount code I can pick up all four of these sensors for $338.30 including sales tax)
Some people report better mileage when they change them -- The early ones had an estimated service life of 60k -- that went to 100k -- now it is never mentioned.
Most of the failures (CEL)we have had in our fleet cars --with many miles on them -- has actually been the heater in the sensor that brings it up to temperature when you first start the car. When you have this type of failure the sensor part is still functioning and will operate correctly after the exhaust warms. We have never noticed any MPG gain after the sensor replacement.
Now when the sensor part fails and you get a code -- that is a different situation -- but we rarely have it happen.
KarimPA
09-03-2015 07:32 PM
