best place to buy gaskets? ?
I took apart the top of my engine today and put it back together in a failed attempt to eliminate a vacuum leak. (Got worse) I tried to re-use the gaskets by sealing them with aviation (like hi-tach).
At any rate my local dealer's price for the gaskets that go between the head and intake manifold are priced at $67 EACH. The gaskets between the coolers and manifolds are like $20 each. Does anyone know where they could be had cheaper? I do not need them fast.
You can get a kit of gaskets for smt. like 300$
Lots of gaskets and seals inside - intake gaskets, exhaust gaskets, valve covers gaskets, timing cover gaskets, pump&thermostat gaskets, valve seals, crank seals and so on.
JLM 20750 IIRC.
WaterDragon (12-07-2012)
There are any number of places in the US to buy gaskets at sensible prices....somebody's doing a bit of gouging big time!
Jaguar uises a gasket system that is fitted dry...no sealnts are used...they just make a mess and ineficient.
You can try Amazon.....FCP Groton....British Parts Place...Coventry West...Jagbits....try doing a google search for Jaguar XJ8 gaskets....you will come up with a host of places.
Tghe most common places for vacuum or intake air leaks are the trunking sealsd from MAF to TB....cracked anti resonator tubes on trunking....full load breather piper on A-bank (right0....part load beather on B-bank (left)....pipe from engine to brake booster.
Simple method of tracing a vac leak is to use a can of earo-start and spray a little on suspect area....if engine revs rise, you have found your leak ;o))
Hi
This JPEG file the shows the gaskets for the Air Cooler to the Intercooler Adapter and for the Intercooler Adapter to the Cylinder Head.
If you want a larger image - use weblink to view it: http://i1178.photobucket.com/albums/...torGaskets.jpg Then you will be viewing it in a new browser screen -then click on the image to view a larger image.
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/27228-best-place-buy-gaskets-xjrx308aircoolerinductionadaptorgaskets.jpg?dateline=1354887747)
You can order these gaskets from Gaudin Jaguar Parts.com - located in Las Vegas NV
Here are their discounted Prices and shipping charges
NCC3018AB - Air Cooler to Intercooler Adapter $7.50 x 2 (Jaguar List Price is $11.00 each)
NCC3020AA - Intercooler Adapter to Cylinder Head $36.75 x 2 (Jaguar List Price is $49.00 each)
Shipping is UPS Ground $ 14.75 --- Total is $102.45
Previous posts in this thread mentions part# MS19440 (I think these gaskets for XJ8 NA -Normal Aspirated not XJR supercharged- engine -seals the intake manifold to the cylinder head- there are 8 of them -one for each port on the manifold).
Jim Lombardi
Jim Lombardi
Last edited by jimlombardi; 12-07-2012 at 08:46 AM. Reason: corrected pricing - had to switch prices on part numbers
Hi
Jim Lombardi
Jim Lombardi
![Icon That](https://www.jaguarforums.com/forum/images/smilies/icon_that.gif)
FS[SouthEast]: S1 XKE OTS Left Tail-light
SCMike
09-22-2015 07:34 PM
1964Daimler
09-09-2015 11:20 AM
