best way to clean engine
RE: best way to clean engine
Hi Monkey,
This discussion came up a couple of weeks ago, but I'll give you the brief version of my answer:
The first and only XJ8 engine I washed lost both of the knock sensors immediately. Not water or corrosion in the connectors, not water or corrosion between the sensors and the mounting studs or bosses on the block. Two bad knock sensors.
