Best way to run meth/waterline from trunk to engine compartment?
I have never done anything like this, however my approach would be:
run the tube through the same hole in the trunk floor that the backup sensor wires go through. make sure to do some alternative sealing work since you will mess up the integrity of the factory rubber seal. then I would zip tie it to the brake lines or anything else that isn't going to get warm enough to melt the ziptie or the water meth transfer hose. I assume it's just a small, clear plastic tube.
good luck
good luck
philwarner
12-06-2021 07:13 AM
rusty37
06-07-2016 04:43 PM
Ziggybeben
08-30-2015 02:09 PM
SingBlueSilver
08-27-2015 02:20 PM
