BG brake fluid
Going to do some maintenance on my 02 when I take off the winter tires - new front brakes -- oil change. Since I have a small leak I am going to take off the valve covers and take a look. Will also do the plugs since all will be dismantled - Plugs are original at 51k).
I was at my local dealer and when I mentioned that I needed some Jaguar brake fluid for a flush he said they are using the BG "ultra dry"product for full replacement. Using the Jaguar fluid for a top up.
The idea behind the product is interesting -- anyone use it?
My theory: Premium fluid is all similar especially the DOT 3 -- manufactures do use more of the specific additives for the Dot 4 and (super) - so I like to keep it all the same.
Received 10,871 Likes
Yes -- the BG is Dot 4. It is the theory about using "super dry" fluid for replacement that I find interesting.
Whatever "synthetic" is when we are talking about brake fluid. Very few brake fluids are mineral based -- and very few cars use this fluid - Green. So the way it is often used today all brake fluid is synthetic.
The main difference from a practical point of view is the compounds that resist moisture in the fluid - and how that works over time. That is one of the reasons that standard performance cars often have DOT 3 fluid in them -- often never listing a fluid change. DOT 4 and (super) while better in the short term is actually worse if left in the car -- it requires a change. Some DOT 3 have higher boiling point than standard DOT 4.
I'm just one that does not like to mix products -- I do it once correctly hopefully
![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
I'm just one that does not like to mix products -- I do it once correctly hopefully![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
I am a long time user and fan of BG products but after hearing of the Master brake cylinder and fluid recall by Honda and Toyota I am going to ask myself if this is the right thing to do before I change what is recommended by the manufacture. I have always followed that rule and suggested that others do the same and now I will be checking even closer.
http://content.usatoday.com/communit...e-fluid-leak/1
http://blogs.consumerreports.org/car...a-odyssey.html
I hope this helps!
I hope this helps!
Gus -- I agree completely. The small difference in cost is not worth the risk - I especially do not like mixing unknown fluids.
But this is evidently what my local Jaguar dealer uses when they do a scheduled brake fluid service on the cars. Longtime dealer - Would surprise me if they were doing this independently?
Also looks like the power bleeder may be part of the issue. I don't have one of the cars listed but Toyota does not spec special fluid on the two Lexus models we have -- and no service interval !
I hope this helps!
I hope this helps!
Just want to make sure we do not mix a fluid/component/standard incompatibility perception with what is a mechanical construction & process issue.
Dimitrigregorio
17
09-05-2019 03:47 AM
Richard_gib
09-12-2015 07:08 PM
