Big issues help!!! 2001 xjr
A few months ago I purchased my 3rd Jaguar, a 2001 XJR in white (117,000 miles)
When the car was sold to me previous owner let me know ABS light was on.
I took delivery of the car and the very next day it had a blown head gasket!
It cost me a lot of money to get the blow head gasket fixed.
After that was done I went ahead and tried to deal with the ABS module.
The ABS module that was on my car was fried so I bought one online from Module Repair out in California.
I received the new module and immediately the car stated "Wrong part fitted".
I had them send me a new module with the correct part #.
Car is still have the issue along with many faults.
Scanning tools cannot read the OBD2 port any more, claims its due to network error with ECM.
Here are my cars symptoms and codes.
1. Car will not get out of 1st gear
2. Transmission jerks when I put it in Drive or Reverse
3. Car tends to over heat since it cannot get out of first gear
4. Power steering slowly getting harder
DASH LIGHTS
Low brake fluid
Trac not available
ABS not available
Restricted Performance
Ebrake light on
ABS light on
Check engine light on
CODES:
P1637
P0171
P0174
P1720
U1261
U1135
B1234
B1697
B1965
4 ECM Fault codes
1 IP fault code
3 DDM fault codes
2 DSM fault codes
Do you guys think my ECM went bad or do I have a circuit electrical problem with the ECM communicating with the rest of the car?
Any advice would greatly be appreciated!
DASH LIGHTS
Low brake fluid
Trac not available
ABS not available
Ebrake light on
ABS light on
CODES:
P1637
P0171
P0174
P1720
U1261
U1135
B1234
B1697
B1965
4 ECM Fault codes
1 IP fault code
3 DDM fault codes
2 DSM fault codes
Received 1,813 Likes
First thing I'd check would be the battery...voltage, corrosion, grounds.
The P codes can be related, check the catalytic converter first, also try unplugging the MAF to see if it helps.
Check this thread for the 1261... https://www.jaguarforums.com/forum/x...1-codes-51510/
The 1135 is most likely related to the catalytic converter....btw, if the CAT is plugged, the car will not run properly, it will do almost everything you describe.
The B codes are body codes, like mirror fault, seat fault...almost assuredly from bad ground.
If I were you, turn ignition key on, engine off, clear as many codes out as you can and then turn key off. Do not start the engine after you cleared codes. Perform a hard reset with both battery terminals connected together for 15 seconds. Start the engine back up and see what comes up from there.
Even though you've dealt with a few ABS modules, I still think you either have another bad ABS module or you may have a bent pin inside the module connector.
Firstly put the original ABS pump+module back on the car, carry out a hard reset -
Then let us know what codes you can pull.
Having the correct part number is not enough on this module, you need it's program code to match also, this can be found on the VCATS list in the spare wheel well of the trunk on a sticker listing all the modules, their part numbers and their program codes. Once you know this you can order the correct ABS module with authority.
There are pins that can bend inside the ABS module?
I cannot find any sticker with part numbers in the trunk
Will check pins of connector today. Thank you
