Bigger tires in back
Then Jag is wrong. Any tire manufacturer will tell you the minimum recommended rim width for a tire with a 275 mm section width is 9 inches. The delta between an 8" inch rim and 275 tire is too great for the sidewall to properly function. The standard 255/40-18 is really pushing it.
I have BFG KDW2's on my XJR in 255/40x18, I've run 275/35x18's on the rear for 2 sets.
I own a Mustang running 275/35x18's same tires on 9" wide rims,
Both sets of tires look OK on both rims, and I use a reliable tire dealer who will not mount tires outside the manufacturers specifications.
What are basing your info on?
I used to run a wheel mfg plant and had specs on max width of tire on a given rim, I cannot remember seeing that these numbers are out of spec.
I think we need to do some research on this.
You obviously can do what you want, but I would never mount a tire wider than 255 mm section width on a 8" inch rim and that's pushing it.
99xk8guy
06-05-2023 06:28 AM
KarimPA
09-12-2015 08:15 AM
