Black Box in Fuel tank? What is it?
I have a 2003 XJ8, with a burned fuel pump. In fact, the 2-pin connector is also burned. I have a replacement pump, but noticed a black box, in-line with the fuel pimp wires (in the tank), and I don't know what it is. I suspect that it's electrical noise filtering, but should find out for sure. I don't want to change just the pump if this is also bad. Does anybody know what this part does? Picture attached.
RCoombes (06-11-2012)
It's most likely something like a T or a Pi filter - a pair of inductors surrounding a cap to ground or a pair capacitors to ground with an inductor in-between or equivalent. See picture.
You can look at the patent filed by the manufacturer, Walbro.
Denso has a patent on in-pump electrical noise filtering, so no doubt Walbro had to go external.
A ferrite bead would do just as well on the external wiring leading up to the tank if you want to just bypass the "black box". Those link leads are expensive, and prone to failure at the connectors.
They must have some effect on power handling because it is *always* the ground side connectors that burn up.
Mine are simply deleted without any ferrite bead or any other noise reduction devices and the sound system works just fine ... the rare times that it is in use.
RCoombes (06-12-2012)
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
