Black cable in the trunk?
I read that the X300 XJ6 premium sound system has like 13 speakers but only 9 are used. The standard system's speakers are still in the car but not connected.
I got the premium system (Alpine) without navigation in mine. The front door speakers (brand new) are still making the same buzzing noise like the old ones only at low volume. Someone suggested bad amp. I don't know where else to look and I don't want to waste money on a used amp if I don't need it. I bet you my factory speakers were ok. Now I'm looking for loose/broken connections.
I would suspect the amp, but it depends on the tone of the noise. I'm a huge audiophile but no electrical engineer. If it is a noise that changes with engine speed, look for a ground wire problem. A inconsistent staticy sound would be loose speaker wires. Although the following would probably cause a noise in every speaker, but do you have any aftermarket accessories attached to the sound system (this can even be a mp3 player connected via tape adapter)? Try disconnecting the CD changer. Maybe that is the source of a ground loop?
These amps are actually 6 IC amplifier chips in one box (4 for the door speakers and 2 for the sub). I think they are made by Toshiba aka low quality. Try changing the "seat position" setting. If it changes anything, its the active crossover which is inside the amp. Only the front 2 speakers have the active crossover.
Has the sound ever gone away?
The ICE harness go on top of the left wheel arch.
For the USA Jaguar did use specific harness, depending on the options.
That why I had to change the whole ICE harness ( from the left of the trunk, through the C post, underneath the rear seat, carpet, center console up to the radio) when I added navigation to my car
WinterJag
16
10-09-2015 07:49 PM
al_roethlisberger
09-09-2015 09:14 PM
