blew a hole in my intake manifold??
johnny screwdriver (12-08-2010)
johnny:
the AJ27 engine has different VVT controls, different intake manifold bolt patterns, I believe a different flywheel and a few more. I believe if you get the complete AJ27, with the parts you havwe from your AJ 26, you can make itr work. See posts here and in the XK forum by AVOS. He apparenly has done an XJR swap, and notes what he thinks it takes for an XJ8. The XJR does not have VVT, so that makes the XJ8 more complicated because the cam sensor arrangement changed between AJ 26 and AJ 27.
Received 2,193 Likes
