blown head gasket!!
blown head gasket!!
Just had my 98 xjr in the shop to replace my fuel pumps. I had no fuel pressure. Got that taken care of. Unfortunetly it turns out that i most likely have a blown head gasket. Great!! The odometer just turned over 100k on my way back home frm the shop.. needless to say i cant afford the labor to replace the head gasket especially since i just forked out over a grand to get my fuel pumps replaced.. is this common for this year xjr and what causes a gasket to go defective? Why me? :/
With the straight six motor head gaskets were not an uncommon problem -- You did not want to overheat the straight six motor - but corrosion had previously always been an issue in the Jaguar cooling system so we were always fanatical with the upkeep of the coolant.
Years ago you had many more dissimilar metals in the cooling system -- today certain coolants are better depending on the particular content of the system that a manufacturer uses.
What was the history/ condition of the coolant in this car?
Sorry to hear of the problem
Jaguar warranty time is 12.3 hours so a real world estimate would be about 18 hours. (12 X 1.5 = 18)
Figure several hundred for gaskets and fluids and you might be looking at a little over $2000.00 but nowhere near $4000.00
That is what I would charge at my shop but it would depend on the hourly rate.
bob gauff
bob gauff
A few years ago, not long after i purchased the car my water pump went out while driving. The car started to over heat and i pulled over and waited for it too cool down.. i wasnt too far from my house so i drove home but i would pull over and shut off the engine b4 the needle would reach the red.. anyway, after changing the water pump the car ran fine and hasnt over heated since. Do you guys think that could of damaged my head gasket and over the years just gradually worsen?
How close to red did you let it get? Aluminum blocks are sensitive to overheating, some more so than others. I've noticed the temp gauge on these jags actually fluctuates, on most other vehicles I've owned it just stays at a certain point and does not move (The downfall of Bosch rovers, they never let you know until it is too late). Overheating can cause head gaskets to blow, however I would still get a second opinion...
There is an interesting and related discussion going on in the XK8/R forum at the moment regarding the temp gauge and engine temp.
https://www.jaguarforums.com/forum/x...e-gauge-62813/
I just had white smoke coming out of the tailpipe of my new to me 04 XJ8. The service writer at the dealership said it smelled like coolant, my wife took it in I wasn't there and now they say it's a bad PCV valve. I'm confused until I actually talk to someone, what does coolant have to do with the PCV valve? It's covered under their 30 day warranty so whatever it is it won't cost me anything.
FS[Western US]: parting out 1999 xj8 vandenplas
bavareze
09-11-2015 02:49 AM
1964Daimler
09-09-2015 12:20 PM
