blue smoke on startup..reasons?
If you definitely saw blue smoke coming out of your exhaust, it can only mean one thing: there was oil in the combustion chamber. There's only two ways it can get there, from the top (valve guides) or the bottom (past the rings). More likely than not oil is seeping through the valve guide(s) when the motor is off. Not a huge concern but keep an eye on your oil level.
