Bluetooth phone and streaming
Hi all, I have a 2002 XJR 100 incoming and i'm trying to plan my modifications. First thing is first, can someone let me know if it is possible to achieve the following:
I'd like to use the original factory microphone for bluetooth phone calls and i'd like to be able to stream via bluetooth and/or via lightening cable as an Aux. Any help would be greatly appreciated.
Received 1,813 Likes
Welcome Johnathan, please take the time to introduce yourself in the New Member Forum, its a site requirement to review posting protocol and rules, it only takes a minute...https://www.jaguarforums.com/forum/n...-intro-must-5/
Your next action would be to use the Search at the top right, you'll find that by putting X308 at the end of the request, mostly only that model will come up. Other than that, you'll get every model...just an fyi.
So, since your new, here's what member Gopi Hira posted back in '17, ...hope this helps and again...welcome.
https://www.jaguarforums.com/forum/x...ctions-144735/
https://www.jaguarforums.com/forum/x...ration-177574/
The CDC bypass gives you audio streaming, the instructions in the link above will explain how to install handsfree calling functionality using a BT receiver and the factory mic.
Rocky15
11-13-2015 02:14 AM
dsetter
29
03-25-2013 04:30 PM
rothe
Audio/Visual Electronics
12-05-2010 03:38 PM
