Booshiba's 2000 XJR Intro/Ongoing Thread
#61
Do any of these models come with grab handles on the interior driver side? When cruising on my long highway drives, or at red lights, I'll occasionally reach up for it but it's missing.
Can I just buy one off Ebay and screw into the existing trim? Or is there some underlying hardware that gives it strength? All my Land Rover/Range Rover, E66, R129, SC300 etc. all had one.
I'd like to install one in this car.
Best,
Booshiba
Best,
Booshiba
#62
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
It was actually the worlds easiest install like other members have stated. There are gromets, covers, line holders etc. Super easy to run line from engine bay through firewall(if yall need I can post pics). I still need to wire electrics for it to illuminate, not sure what to tap into for that.
Lowest vacuum reading was around ~-21 when downshifting aggressively and highest boost reading was +14 @ WOT from a standstill to redline.
I used the AutoMeter Boost Gauge Model 4303.
Advice from experience here: Absolutely go with a quality brand. I first did the autozone brand Equiis or something like that, and it was trash. Brass fittings were leaking and the gauge itself felt very Toys-R-Us.
#63
Best,
Booshiba
Best,
Booshiba
#64
Thank you for getting back to me. I will see what is behind the trim and see if I can do it. With the ergonomics, my stature, when I rest my elbow on the door It is perfect height for me to grab onto a handle....I NEED THE HANDLE lol
#65
#66
Where have you placed the gauge? It won’t be difficult to get a feed for it off something close by, there are also wiring diagrams available on this forum somewhere. If you’ve placed it by the centre console an easy way would be to hook into the the ashtray illumination wires or if you’ve put it on a pillar you could probably hook into the roof console illumination.
#67
#68
I’ve had a quick look at the wiring diagram and there isn’t a way you can connect it to illumination without disturbing something unfortunately. According to the diagram the wire colour for the instrument pack illumination is red and blue, alternatively you could try and route it to the clock in the centre which has a solid red wire for illumination.
Either way you’re going to have to disturb something to get it hooked into the instrument illumination circuit. Alternatively you could wire it to a permanent live but it would be lit up constantly whilst the engine is running.
#69
#70
If you can get two lengths of wire that will reach the other side of the car there is a feed for a 12V socket plug at the back of the glove box.
This would’ve been for an additional socket or the optional torch, but I see no reason why you couldn’t plug into that for your gauge. From memory, it only works with the ignition, but best doublecheck with a test light first.
Joe Gandalf
10-03-2018 12:44 AM
scottjh9
09-12-2018 04:35 PM
