Boost gauge installed. Only 10psi Of boost ?
So I installed a boost gauge in my center vent in the clock position. Pics coming.
my issue as I suspected I am only getting 10psi of boost. Maybe a bit more but not 13 to 14 which seems to be what I should have.
Im thinking possibly a weak fuel pump. The car runs fine but initial start up takes a little longer than when warm which I have read can be a clue.
What else should I look at for low boost on a good running car.
So I installed a boost gauge in my venter vent in the clock position. Pics coming.
If you want a bit more boost, you can install a slightly smaller (6%) pulley on the supercharger. This is an easy upgrade as it does not require machining of the snout, nor chipping of the ECU, and you can use the same belt. Another thing affecting the boost is the efficiency of the charge cooler. When the intake air gets too hot, the ECU will start reducing the boost. With a smaller supercharger pulley, it is advisable to also install a higher efficiency charger cooler radiator and a higher flow electric pump for it. You can get a lot of info on these upgrades if you search the forum.
sounds like my 10psi May be normal based on other replies although the factory spec I read was 13.6 psi.
I found other posts referring to the two fuel pumps being an issue with performance if one pump isn’t working. Not sure how it affects the boost but I assume a lean condition leads to reduced boost.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x64/boost_pressure_3bf03b1649e2945844b779505eac34c7f5f06a4f.jpg)
11.6 psi is the maximum boost pressure declared. This could be achievable in certain ideal conditions - new air filter, with denser air (on a cool day at sea level) etc.
Z07Brandon (10-24-2020)
Not quite. The Jag supercharger system is "power on demand" or "boost on demand" type. The higher boost comes in mainly during acceleration and depends on how hard you want to accelerate. During cruising at part throttle, the boost is much smaller.
the more wheeeee you hear the more boost you are making
I don't know how ECU can adjust the boost just because it does not control the bypass valve? Valve is controlled solely with vacuum by the same vacuum line what goes to the evap etc. Atleast this is how it is made in my car. I did even have massive vacuum leak in the particular line and it did not affect to the supercharger at all.
With regard to your case of having good boost even though you had vacuum leak in the line related to the operation of the SC bypass valve, if there is a vacuum leak it will result in the bypass valve not opening or not to opening fully. This will cause higher or full boost all the time. How the bypass valve operates is that, at high vacuum the valve will open meaning low boost; at low vacuum due to wider open throttle (or due to leaks in the vacuum line) the valve will close meaning high boost. The valve is normally kept closed (high boost position) by its spring; the vacuum acts against the spring to open the valve and reduce the boost.
kansanbrit (10-24-2020)
Newby
06-02-2012 06:56 PM
carlorner
06-08-2011 05:05 PM
