Bought it! And now I have transmission issues WEEE!!! lol
Well, I bought it and right as I drove it away "gearbox fault" appears on the display. It threw the following codes P1111, P1730, P1734. It stalled once on me because of the transmission. It drives fine in what I believe is 4th gear and reverse doesn't always work. Any ideas? The transmission was rebuilt 25k miles ago (a $4000 job), could it really need to be rebuilt again? Any advice is appreciated.
I'm in the middle of doing the tensioners on it, so the transmission has to wait. It was rebuilt in 2006 so I doubt that the warranty would cover it (if it exists). If the worst comes, I'll buy a rebuilt unit and swap it out. The fault codes indicate "gear control malfunction 1,2,3,5" I can trick it into reverse if it registers a fault. This leads me to believe its more of an electronic issue than mechanical. Plus I do not hear grinding noises, which is a huge bonus. I can get the gears to shift by using the J-shifter and do it manually starting out in 2nd. The gear changes are not the smoothest, but it does work. I'll flush the fluid once the tensioners are done and then take it to a Jag shop anh have the transmission computer looked at to see what she is saying.
KarimPA
09-03-2015 07:32 PM
