Brake Fluid Low
Brake Fluid Low
Hello,
My first post - having just purchased a used 2001 XJR with 75,xxx miles.
I have a 'Brake Fluid Low' message on the console and the handbrake light is on. The car drives fine and brakes well including the abs kicking in. I have inspected the fluid and i would say that it is over full. I have unclipped the sensor wire and reconnected all to no avail.
1. Wondering if anybody else has experienced this?
2. Are there any diagnostics i can perform to check the voltage/resistance etc?
3. Is the sensor a part of the fluid resevoir and if the fault is with the sensor do i need the fluid resevoir as a replacement?
Thanks,
Darren
Thanks,
Darren
Received 2,194 Likes
jump the 2 pins on the connector to the brake reservoir to verify operation, if the light goes out, you need a new reservoir/sensor assembly. for the prk brake pull up on it and try releasing again, that switch is very sensitive to ANY application of the brake handle. And if its released, same thing, jump the connector pins on the switch after removing the brake handle cover around the base to check operation( I have never seen 1 fail in 13 yrs, but then IN flat Texas we dont use the park brake )
The following 2 users liked this post by Brutal:
andrewrichardson (06-27-2013),
Jhartz (06-24-2013)
Brake fluid low warning
I have had the ABS light on for a while now, with messages ASC not available, TSC not available, with no ABS or traction control function. I checked the wiring on all wheel sensors and the sensors themselves, and found no problems, so I stripped out the ABS block and ECU, opened up the ECU hoping to find the dry solder refered to in other posts, but it was all fine, sealed it back up , fittied it back on the car, bled up the brakes, still have the ABS light on and the ASC and TSC messages, then about a week later, I got the brake fluid low message, with the red light and the handbrake warning light on. Brakes work fine except still no ABS or traction control functions, fluid level is fine. I am assuming it is related to me stripping out the ABS unit and bleeding up the brakes, so my next step is to get a "new" ABS block and ECU and fit them, unless anyone can point me in a cheaper direction. I sdont mind driving around without ABS or Traction control, but even though I know there is plenty of fluid and no leaks, i dont like driving with red warning lights on.
Sorry it's taken me so long to reply, thanks for the advice, low fluid light and warnings went off not long after I posted, ABS and the rest are still on, but still not got round to booking it in for a check up, I don't use the Jag too much at the moment anyway, only done 1500 miles in a year as I am busy at work, I use my trusty old Rover 75 oil burner for that. No way am I taking the Jag down any mucky old railway access roads.
I got the pin diagram for the ABS module on the forum, got a multimeter and went to work, guess what................ Left hand Front Link Wire is goosed.
9 months the ABS light has been on and I have had TSC not available ASC not available all that time.
During that time I checked all the sensors with a multimeter, cleaned all sensors and connectors and the reluctor rings, stripped out the ABS pump and module, opened the module and checked the solder.
All because I am Scottish and as tight as a ducks whatsit and refuse to pay someone £60 to plug it in to a laptop and say "its your left hand front Link wire thats goosed"......... I'd rather find the fault myself, and I now have done thanks to this forum, and all it cost me, apart form all my own time, is £14.50 for a used link lead off Ebay.
Thanks guys, would never have found it without you.
Should add it was an internal break in the white wire in the link lead, right at the sensor end, if it had been in the middle of the lead I would have opened it up and joined it, but it was right at the bottom of the lead where the hardened shirk wrap meets the multi plug, so I treated myself and splashed out the £14.50 on a "new" wire
Welcome to the forum Rob,
See Post #3 in this thread for the test procedure to identify where the fault is.
When you get a minute, please follow this link https://www.jaguarforums.com/forum/ne...-intro-must-5/ to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Low brake and parking brake
I think I have faulty cable/connector thats comes up when heated... The brake fluid container is already replaced, but that didn't fix the problem.
The warning is most of the time away, but comes back after the engine heats up, and, ALWAYS the combination of parking brake and low brake fluid.
It can dissapear and come back randomly.
I did disconnect the connector to the ABS/TCS box, and cleaned it with some contact spray. Didn't make a difference.
As these two errors always come up together, could it be I have _one_ problematic cable, that is shared by these to modules?
Anyone?
Anyone?
aholbro1
08-05-2021 05:02 AM
Richard_gib
09-12-2015 07:08 PM
Wes Steenrod
09-06-2015 06:52 PM
