Brake fluid low ... once ....
So I drove 2 long highway trips this early week, and decided to give the car a full wash this morning.
After that, drove the usual 3 km uphill, then 5 km downhill back home.
During the downhill, I decided to perform some stronger braking, just to build some heat, and to clean the disks / pads from built-up from the normally relaxed and soft braking I do.
It went all well, brake performance came back after 3 times, only to have a 'low brake fluid' warning in the dash the 4th time.
But no drop of brake performance, no weak pedal, nothing.
I stopped, couldn't find a thing, and on the (slow) way back home, the message never came back.
Not even after some further heavier braking.
As it is the brakes, I kind of wonder / worry what the heck happened, and what I will need to do to either replicate the problem, or prevent it.
PS. No wash water in the engine bay or electrics, I am sure of that.
I have never looked at it, but is it a float, or a contact kind of sensor in the reservoir? Do you know?
Ha, that makes sense ... maybe ...
I know braided lines from sportbikes, never thought about it for this car.
Guess they are still the original OEM.
I googled a bit for sets, but supply seems limited or out of stock.
Any suggestion for a set of 4?
I don't remember, but I think they are typically a float.
Don't see how a bulging brake hose is going to cause a low fluid alert, but those hoses do go bad overtime. My wife's Maxima failed an inspection a few years back; inspector said it was a bad caliper. So I buy a new caliper, bust some wrenches and hands getting the old one off, and while bleeding the system (wife is a real pro at pump, pump, HOLD), noticed the problem was a bulging hose . . .
ericjansen (12-23-2017)
Will order a set, guess changing some 20 yr old brake hoses is an healthy idea anyway ....
cchong
10-28-2020 10:57 PM
blackjaguarxk8
07-07-2018 01:31 AM
Len Stanley
02-24-2014 07:57 PM
