Brake light switch repaired
For the longest time, I would go into failsafe mode when using cruise control. Based on other posts I figured this is related to the brake light switch, but I did not want to spend $200 for a new one (rip off).
The other day I finally removed the switch which does require a bit of body contortions. The switch itself is a fairly simple mechanism. There is a spring, a miroswitch and a pcb board with about 6-8 wires attached. Not much to mechanically fail and, since my brake lights work, safe to assume the microswitch is good. That leaves a wonky electrical connection.
Although the solder joints all looked good, i resoldered each of them using a generous amount of flux. Took all of 5 minutes. Remove and install of the switch is the bulk of the time.
Sure enough, everything now works as it should. 5 minutes work beyond the R&R saved me $200.
When you reinstall, just make sure pedal is making contact with switch. You should hear it click. If not, adjust ppsition accordingly.
Just completed the same. Switch removal is not a huge deal. I took off the knee panel under the steering wheel (4 t27s) but that was likely unnecessary. One 7mm and 1 8mm to remove the single nut/bolt.
Reinstalling the switch is a bit more of a pain as you need to slot the tab onto a short stud. I laid under the dash to complete this.
Cleaned the switch and reflowed the solder joints. Lets see if that solves my problem
motorcarman (01-23-2023)
