bumping sound in the back
I have a 99 XJR- 109K, runs great and drives very well, I have noticed a "bumping sound" in the back of the car. It sounds much like the rear passenger door is not closed firmly whenever I go over bumps in the road nothing in the trunk, and door shuts firmly. I have noticed it getting a little worse over the last 500 miles. I can't feel any reaction thru the steering, it just sounds like the back door is not all the way closed. Sure could use ideas and things to check. tks
The following 2 users liked this post by rocklandjag:
duplicates (08-03-2015),
XJRay (08-06-2015)
+1 exhaust hangers: particularly noisy in cold weather (I hit them with silicone spray once a month), once it gets over 90*F, they get quieter (or I am getting deafer).
Loose battery or junk in the trunk can get noisy (especially if your spare tie down is missing or loose).
Or the lower shock mounts have deteriorated badly.
XJRay (08-06-2015)
Received 13,088 Likes
+2 on exhaust hangers.
Also, the rear shock upper isolator bushes can deteriorate over time (Parts 13 & 14 in the diagram below, or parts 21 & 22 if you have the adaptive damping). If these rubber bushes disintegrate, the washers on the shock shaft can bang around on the upper mounting plate, Part 6. These upper shock mounts are positioned just behind the outer edges of the rear seat, so when they begin to knock the sound seems to come from just inboard of the rear door latch.
Cheers,
Don
Cheers,
Don
XJRay (08-06-2015)
