Burning Issues!
Old 12-27-2010, 07:54 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Stu:
This ain't rocket science. Get a bright light, a mirror and some rags and have a look. It is PROBABLY either the water pump (it leaks around the shaft seal) and you will see coolant below it, a cracked "riser", the plastic thing that the radiator hose connects towith a cap at the front of the engine (known to crack and leak, therefore an aluminum replacement available), or the plastic crossover pipe just in front of the aforementioned riser.
Good luck!
99xk8guy
05-28-2024 09:36 PM
ZJag
26
09-05-2016 03:33 PM
perfectson
11-01-2015 10:46 AM
powerhouse
09-09-2015 08:08 PM
Quick Reply: Burning Issues!
