Burning rubber smell under acceleration
burning rubber and burning oil are distinctly different Marko!
You only need a drop on the manifold for oil to smoke and smell.
How close is the exhaust to the rear tires? I'd guess the gases would be cool enough not to trouble the rear tires though...
S.C. belt slip? tensioners to check?
If the cat's go bad they throw gases off and the O2's would throw a code, fuel trims would also be out of normal range, is it using more fuel? any codes?
hope this helps
hope this helps
WOW ... patina is the green stuff that forms on copper but now is pretty much used for all kind of grime which is left on machined parts, ie oil, solder, small metal shavings etc ... it is normal for an exhaust to smell when it is new. There is no way for them to have the inside of the exhaust absolutely clean so you smell it burn off. A magnaflo or flowmaster especially if they have any kind of matting inside the muffler.
