bypass gooseneck
bypass gooseneck
hello all,
I am currently chasing down coolant leak(s0 from the valley area. I just assumed the leak was from 22 year old hoses in the valley. I changed them and thought everything would be fine. No, still signifigant leak.
I disassembled and inspected the valley and I think the ls coming from the bypass gooseneck. there is a boss machined and drilled and threaded for a 4 bolt flange for the gooseneck, but I have a 3 bolt flange gooseneck and it is leaking where the 4th bolt would be. Do 2000 XJR"s normally have a 3 bolt gooseneck. Where might I get a 4 bolt gooseneck.
Thanks,
Dave Redline
Thanks,
Dave Redline
So the induction elbow are all 4 bolt. There isn't a direct coolant line in that area.
If your engine has the AJ27 throttle body, they're fitted with a coolant line - that could be leaking as a wild guess.
The header tank can crack and leak coolant down so check that area also.
I cannot recommend the Jaguar site highly enough if you're a hands on owner...
https://parts.jaguarlandroverclassic.../brand/jaguar/
