A/C Compressor noise
Don B (11-10-2017)
My 1999 VDP AC compressor is making a lot of noise. Use a screw driver on the AC compressor when it is engaged to verify that it is making the noise.
Instead of messing around with lubricant, etc. I decided it was time (17 years) to replace the compressor. I bought a Denso compressor for $280 and am going to have it installed by and ac specialty shop. I am researching if I need to replace the drier (3 to 4 year life span?) and / or condensor replaced when i replace the compressor.
It has been reported that the compressor is a little difficult to remove - it is at the bottom of the engine and some items have to be moved or removed to get it out. What might be a $300 - $400 job may be $700 - $800 on the Jag.
Look to see if you have a Denso pump and the Denso part number ( looks like one ) . Yours may be a series 6 or 7 as mine is a 10 PA on the X300 . You may have a bad bearing in the compressor clutch that may be able to replace without touching the compressor as they don't last forever . You can replace the clutch bearing only . You may be able to remove the clutch while keeping the compressor mounted to the engine and save alot of money . You can find smaller repair parts on the Centuryautoair website . Yes on the dryer replacement if you overhaul or replace the compressor ( 30 - 35 dollars ) . Don't lose the O - ring seals on the refrigerant lines . If you take your compressor to a shop they can break the nut with a fee/ tip . I have the specific X300 part numbers but not the X308
https://www.shopcenturyautoair.com/s...ppondenso.html
Clutch bearings : appears to be part number MT2027 / 52mm outer diameter x 22mm Thick
https://www.autozone.com/cooling-hea...07355_150085_0
https://www.shopcenturyautoair.com/s..._Bearings.html
https://www.jaguarforums.com/forum/x...emoval-120349/
Clutch bearing replacement ( on car )
katar83 (11-12-2018)
SonicRiot
05-24-2007 11:32 AM
