A/C has taken a vacation
I have a 2000 XJ8-L and up until now the AC has worked perfectly. Today I took off in it and the ac compressor isnt coming on at all. I was just wondering if something going haywire electronically would throw some code or something? Does the climate control lock out the AC button LED if the freon has leaked out? Because the panel still lites up the AUTO-AC buttons. But no compressor engagement.
Blaze
Blaze
RE: A/C has taken a vacation
Try adding some ac coolant to the system. When the compressor on my 95 XJ6 stopped working do to a leak, after fixing the leak and recharging the system the compressor came back on as soon as I added enough charge to it. It is a safety so that the compressor doesn't get damaged as the coolant also has the lubrication in it.
Hope this helps.
Hope this helps.
Thats what Im talking about jumping the sensor so it would come on. If it comes on at that point then I know the wiring is all good to the compressor and it would have to be a bad sensor or low charge. I hate hooking the gauges up to it because the last time it was checked the little valve spewed a little freon when the hose was disconnected. Not a lot but more than it should. So I didnt want to hook up the gauges just to find it was charged and it was a wiring problem. I find it hard to beleive that the freon leaked out in 9 hours, but I know its not impossible.
Blaze
Blaze
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
