A/C replacement suggestions
I am going to price an AC Delco compressor, if available, when I am at work tomorrow. What brand compressor do most people go with? I found a new Denso for $300 or so. I am also going to be replacing the condenser, unless it is the fin&tube style(I doubt it is). What parts do you guys typically use? I am really getting into it this weekend with the vanden plas. I just got my ABS sensor ring socket for $130 from motorcarsltd.com and I am doing both front wheel bearings. Unfortunately, I wont have parts in time to do the A/C this weekend. I also need to fix the endless heat from the passenger side floorboard problem. Thanks in advance for you replies.
-Rob
-Rob
KarimPA
09-03-2015 07:32 PM
