A/C suddenly blowing hot air
I pulled in to the grocery store today with a/c blowing so cold that I had just turned it down on low. I parked, turned the a/c off, then turned the car off and went inside. When I returned and started the car the a/c is blowing hotter than the air outside. 100 degrees in San Antonio. Car is 1998 xj8 vdp. Does anybody have a clue?
As old as your car is (I have a 98’ also), besides what Randy mentioned, checking the A/C compressor relay (and all the other brown relays throughout the car because of age) would be a great place to start. Inside the relays where the contact points are is where they burn up at. If it’s not terribly burned up, they can be cleaned up with a small flathead screwdriver or a file. The most common brown relays that fail in these cars is: starter, A/C compressor clutch and fuel pump. These are the higher load items that make them wear out quicker than the rest. Now, I’m not saying that your compressor relay is bad but, I would start there because you said it was blowing cold a short time before it started blowing hot. Unless an A/C hose decided to blow while you were in the store, it’s possible because of the engine heat soak could’ve made the old rubber hose blow.
Yes indeed, that foam will break down over time, and as it disintegrates, plays havoc with
the air flow design. Getting to where the problem is and extracted is difficult and time
consuming. That foam was never intended to last this long and the engineers seem to
have been clueless as to the issues it would cause.
AH101
06-15-2015 12:46 AM
Francesca
101
06-14-2015 07:23 PM
