Cabin heater problem
Hi,
I'm a newbie here and I hope you can help me with my first query.
I've got a 1999 XJ8 3.2 and the internal cabin temperature gauge is reading very high, today when I went to the car and it was cold the external gauge read 4 degrees while the internal gauge read 31 degress. By rights both should have been the same.
The heater is not blowing very warm even when the car is up to operating temperature and I think this might be linked. Can you help?
Cheers, Richard
Cheers, Richard
The "interior" temperature is not reading the temperature of the interior, but rather, the temperature that you wish the climate control to maintain for the interior. So it's not reading the ambient temperature and displaying it like the outside temperature sensor is doing.
That being said, you do seem to have a problem if you are not getting heat when the climate control is set to 31 which is probably near the max setting. I'd try a couple things before throwing parts at it.
Turn the Auto and A/C settings off, set the temperature to max... do you now get warm air? If you are getting some warm air but not hot, then it is probably the heater control valve if your temperature guage is running at the normal.
Search the this forum and see what others have found on this issue, I'm sure you are not the only one that has posted something similar over the course of the last several years.
Does your car have an auxiliary water pump for the heater? My 95 xj6 did and all I needed to do was clean it out. This is what it looked like http://www.gusglikas.com/AutoRepXJ6heaterpump.htm
I have a weak heat problem too. I will be installing a second hand heater control valve. But I will clean the pump and flush the heater matrix whilst I'm in there.
Thanks for the pics.
Use this link http://www.gusglikas.com/AutoRepXJ6heaterpump.htm and click on the first two photos and you will see where mine was located.
I was thinking of using one of those radiator flush liquids to dissolve the scale.
Thanks,
Dan
Hi Dan,
I didn't clean it, I decided to replace it. They were about £70 new and I though maybe all the gunk will never come out and the problem might persist.
There are a few on Ebay for about £35 but I needed one quickly.
Good luck, cheers.
Toasty Rich.
Good luck, cheers.
Toasty Rich.
