Calling all who use Torque Pro
And the ELM Bluetooth adapter. Am I the only one who can't read coolant temp? It always shows"no data". Also, my 02 XJ Sport started running rough/misfiring randomly at stop lights. So I was checking to see if any codes were set. There is a p1111, but I researched that and it nothing to be worried about.
Brandon
Brandon
Z07Brandon (11-02-2017)
To echo, I use it as well and have zero issues reading coolant temp. I don't remember what brand adapter I have, got it on Amazon years ago. But I do leave it in full time unless I need to check another car or something. The only hiccups I ever have is every so often, it stops responding to connect to the phone, but restarting my phone clears it instantly. Almost like clearing the cache or something, and pretty sure it's a phone issue, not an app/adapter problem.
The following 2 users liked this post by CharlzO:
King Charles (11-02-2017),
The following 2 users liked this post by King Charles:
Don B (11-02-2017),
The following 2 users liked this post by ericjansen:
Don B (11-02-2017),
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1200x2000/capture_2017_10_27_12_58_00_1ca2650b00dc8d3610749aa4a81ac655b4738bc1.png)
For what it's worth, the car displays coolant temp fine from the instrument cluster. But will get to it tomorrow.
That's insane! A tip for anyone who is new to it.
1st: Make sure you don't have the torque app running. It won't connect to obd2 adapter if so.
2nd: Turn your phone's bluetooth on
3rd: Connect the obd2 adapter to obd2 port
4th: put key in ON position only
5th: Go to bluetooth settings on your phone, and pair them.
6th: Go to app, and you should be set
7th: start the car and explore.
As I said, will update you guys once I am able to read coolant data.
I think a lot of it is just hit or miss though. For example, if I get out of the car, and go into the store our house or something, and leave Torque running on my phone, it'll reconnect just fine when I come back out and start the car back up. Also, on my V20 for example, the app will auto-enable BT on the phone to connect even if I don't do it manually. I think some phones and adapters are just going to have a preferred order of steps to be most reliable for connection wise. So when you find a way that works, stick to it!
ericjansen (11-02-2017)
Z07Brandon (11-03-2017)
I presume you know that there are 2 banks on your car, and that Torque can read and display both of them?
If you set them up next to each other, you can check if things are balanced.
The most important are STFT1 + 2, and LTFT1 +2.
The other fuel trim readings are further down stream, after the cat.
The following 3 users liked this post by ericjansen:
