Cam cover cracks
Cam cover cracks
I removed the cam covers from my 1999 XJR as part of the tensioner replacement job, and found cracks in the several of the mounting bolt holes.
Each side has three cracked hole locations. I'm attaching some pix.
I don't **think** these are fatal flaws -- there seems to be plenty of non-cracked surface that will support the 12 Nm of bolt torque.
But I'd be curious what others think. And has anyone else seen this?
-- Curt
-- Curt
Coil cover cracks! Yeah, a couple of them on are cracked on the used engine I am swapping into my jag. It is relatively low miles too. My original engine had 176k and they were cracked in one or two spots. I dont think its a big problem at all as long as there is a majority of them evenly distributed. Hooray for crappy plastic! Someone should make some aluminum ones etched with Jaguar, or something.
jimlombardi (07-20-2012)
You will need super glue, baking soda and a flux brush.
Lay out a teaspoon of baking soda on a piece of paper to have it ready because you have to work fast.
First, glue the pieces together as normal, but immediately sprinkle some baking powder on the glued joint on all sides. Wait a few seconds to setup. Then brush off the excess with the flux brush.
Second, build up the joint by flooding the area with some superglue, sprinkle baking soda, brush off. Do several layers.
The resulting joint with fillet was very strong on a broken tail light tab that is meant to hold the interior trim in place. Probably stronger than the original part.
The baking soda does speed the drying -- as it is wicking out the product. Many say that this is actually making a weaker joint. -- but it does allow the product to act as a "filler" .....fine if you are going to sand and cover it with another film.
I think a better way to go is the use of an accelerator or activator -- I use them all the time with my woodworking.
-- Curt
-- Curt
It is used world over for rare bell housings to repair them even aluminum and steel blocks (we don't we weld em unless super rare but it is) and if you add a iron powder to it you can even get a magnetic draw for flash coatings or powder coatings.Or you could paint but it is as hard as steel and will hold substantial tork and will have no problems to hold the OEM spec tork settings.
I can tell you more T88 rolls though Barret Jackson than anywhere else on the planet. I am not sure what its original designation was for but I do know Atlas Fiber carries it and for the serious restoration buff that wants NO come backs and to keep a solid reputation it is a must.It dries clear and as I said it is bias to put additives in it.Just a suggestion.ALSO NOTE IT REPAIRS CRACKED WOOD COATINGS as many guitar and pool cue makers use it for finish coating .There is my loose lips for the month.
I know this but cant get a starter on - Geeesh
plums (07-22-2012)
As to strength or suitablilty, anyone can try it out as it only costs maybe ten cents worth of materials and a bit of scrap plastic to try the technique.
Maybe it'll work for your starter too ... as long as you never want to remove it again
Dickie_L_J_O
09-13-2015 07:44 AM
jagent
09-12-2015 09:10 AM
