Camshaft Senor
blackhonor9 (01-04-2014)
The engine is mounted longitudinally. The front is towards the front of the car. The left side is on the drivers side in the US. So the rear of the cylinder head is near the firewall.
When you have time please visit the new member area and introduce yourself:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
This displays the single sensor location (#6) on an earlier version of the engine. In your case there is one located on each bank.
https://www.jaguarforums.com/forum/x...02/#post854402
Graham Royls (01-08-2014)
OK, now the question: What else could it be?
Well, it could be it could be the PCM or a number of other things such as one of the ignition modules but there is almost zero probability that it is ALL the coil packs. The P0300 code alone does not provide enough information to fire the parts cannon but have fun!
I changed the coils. The car runs better but not the way it should.
I know that everyone here doesn't think it's the camshaft sensor. What else could it be? I checked the timing, timing tensioner, added fuel injector cleaner to the fuel. I will have the ECU tested. If I disconnect the Camshaft sensors, should I get a code? If not or if so, would that be my answer to my question?
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
02-11-2016 06:03 PM
vincent661983
10-29-2010 08:25 AM
