Can I do it myself?
Hello and Greetings
I just extracted these 3 pages (thermostat R&I) into the attached PDF from the JTIS cd.
You will have an easier time opening these attached files with mozzilla Firefox brower than Microsoft Internet Explorer (It uses a lot less computer resources).
Here is the PDF file:
Jag XJ8 Thermostat R&I.pdf
Also just added the Draining of the Cooling System instructions:
Here is that PDF file:
Jag XJ8 Cooling System Draining.pdf
I think you will like the pictures and instructions.
Jim Lombardi
Jim Lombardi
Jim,
Two comments: you have software and capabilities that have eluded many of us mere mortals for years at cut and paste out out JTIS. Second, I have not forgotten your request for comments on your data base. Tomorrow is a day of rest, reflection and responding to you.
I was pouring concrete in a sleet storm yesterday and building a deck on my public service project with snow on the ground today. See GilmerKidsKottage.org
my 98 with 60,000 miles just started to run hot when I come to a stop for more than 30 seconds, or in heavy slow traffic. On the highway, it will run at normal temperature all day long, so it is a weird little problem. Didn't realize highway speeds could cool the car that much without the thermostat working correctly... I thought the t-stat would be the simplest most cost effective start towards solving the problem...any other ideas?
avt007,
how many miles on your xj? on a side note, i'm starting to notice an ever so slight clunk over bumps coming from (i think) the front suspension). Admittedly, I'm a little picky, but the noise ruins the ride for me, and makes it seem like the car rides worse than it actually does. Anything common fail suspension wise around 60K? Bushings are my first guess, but anyone feel free to chime in with other suggestions.....this forum has a lot of collective knowledge...
If the fans run at shut off they are probably OK. Back to the thermostat. These cars, with their aluminum heads and plastic parts, are very sensitive to overheating issues. Couple that with the fact that the temp gauge is really an 'idiot gauge' and that any high temp is really a serious cry for help it is time to do something . . . today.
Don't worry about the suspension until you get the cooling problem fixed! You could kill that engine in a few minutes.
As far as suspension issues the most common are sway bar bushing, and wishbone bushings. Both fail more often than the average car. Check out the FAQ Sticky on the XK8/R forum. There is an alphabetical list of issues on these cars. Your drivetrain/suspension is the same.
