Can radiator on 98 XJ8 be repaired?
If you set it where it’s still wet with coolant, it’ll never work. To do it properly, you really need to pull the radiator out, that way you can rinse the area off with water, dry it off either with compressed air or maybe a blow dryer. After that, you need to carefully remove the old epoxy, blow it off, hand sand about an inch above and below the damaged area throughly, blow it off again and apply epoxy the entire sanded area. Let it sit undisturbed for 24 hours minimum in a warm, dry area.
sdblacksheep (11-05-2021)
sdblacksheep (11-08-2021)
Since I would have had to remove the radiator to properly repair the plastic end cap where it was cracked, I bought a used one for $70. Best part was that I was able to remove old one and install the replacement without having to disconnect the AC lines or evacuate the system. A little tricky, but possible. While at the junkyard, I also bought the wood rimmed steering wheel, front and rear seats, 6x9 "subwoofer" and amp from the same Vanden Plas. Didn't need the seats, but much too nice to pass up. Would like to find XJR wheels as long as it's turning into a mutt anyway.
sdblacksheep (01-07-2022)
