cannot fill fuel tank
Old 01-16-2023, 12:29 AM
xalty's Avatar
Received 1,060 Likes on 851 Posts
Originally Posted by alamp0174
team i need some guidance and or help!! Check engine light is on and can not pass emissions test. Had it in the shop and stated the issue was to do with a leak in the rear canister. Not able to find a new replacement part because it is discounted. To add to the issue went to add fuel today and the fuel will not enter the tank. Did anyone come up with the solution?
no year
no model
no answer
  #42
Old 01-16-2023, 05:32 AM
RandyS's Avatar
Originally Posted by ALamp0174
Team I need some guidance and or help!! Check engine light is on and can not pass emissions test. Had it in the shop and stated the issue was to do with a leak in the rear canister. Not able to find a new replacement part because it is discounted. To add to the issue went to add fuel today and the fuel will not enter the tank. Did anyone come up with the solution?
Hello there. your public profile says you have a 2003 Jaguar XJ8 so may we assume that to be the
car you are inquiring about? If so, there are several solutions mentioned thoughout this thread that
have worked for forum members. Turning the gas nozzle 90 degrees seemed to work for some.
1995XJSGuy
09-08-2020 12:09 PM
Joshua Hake
11-30-2019 07:25 PM
BobbyDing
10-27-2018 08:34 PM
Paulbx62
12-03-2017 08:28 AM
elwood
05-23-2007 06:20 PM
Quick Reply: cannot fill fuel tank
