Cannot open trunk
Cannot open trunk
So, I hit the stupid 'valet mode' button on accident which normally shouldn't be a big deal but its not switching off and I don't have a electronic fob. I am unlocking the drivers side door with the black key but it is not registering and the trunk remains locked. This has happened before and I simply unlocked the trunk with the key and did a hard reset to clear the code but when I try to turn the key in the trunk now it seriously feels like I'm going to break it. So is there any other way to clear the valet mode that anybody knows of?
Thanks!
Thanks!
WD 40 in the key slot might work. Ebay has used key FOB's for $10 to $40. You can program it yourself.
Remove the license plate and use a long slotted screwdriver in the top right hole to manually release the latch. A small inspection light will help you find the right spot.
Don't cut or destroy anything to get into the trunk. Don't remove the rear seat.
Lots of mis information out there.
Please post any solution you come up with. I've got a similar problem with the drivers door lock. Valet mode doesn't have anything to do with it in my case but my key will not turn the lock. Mine has never worked but I've got a fob, Question, does drivers door turn clockwise from top like the trunk? I get about a quarter turn with no resistance when I turn clockwise, counter clockwise it gives just a bit (one-two degrees) and I can hear the tumbler clicking if I jiggle it back and forth, but after that it's a brick wall. I've tried silicone, WD-40 and even a bit of powdered graphite and nothing works. Haven't been able to get much help on the forum beyond those fixes, maybe if your's is a lock cylinder malfunction it will help me solve my problem.
Lear, are the old Jaguar remotes on Ebay capable of being reprogrammed to a new car? I know some FOB's by Ford, Mercedes and BMW can not be reprogrammed to a new vehicle. If they are indeed able to be reprogrammed to our Jags I'm going to pick up a couple to toss in the drawer for when I might need one.
Thanks.
Back on topic, I went to pull parts from a 2000 VDP and the wrecker yard did not have the key. I tried the license plate entry and it didn't work. The owner of the yard tried to bang on the release handle with a hammer LOL I told him let me try. I pulled off the push for the trunk release, looked inside and noticed that the piece that would apply contact to release the trunk was not in place. I put it on the end of a pencil and push the appropriate area and "presto"! The trunk opened and I was able to retrieve the rear lights for spares lol. This might be another option if everything else fails. In my case it wasn't a dead battery but the contact had fallen and was not in place.
Thanks for the replies guys...I havent had time to try to go through the license plate holes yet because being a full time college student/working full time doesn't leave much time for anything else lol. I did have another thought though, what if I just connected a code reader to the car and cleared the codes. You think that would disengage the valet mode as well?
Shine a tiny flashlight in another hole and you will see the latch. It will take
15 minutes the first time. Once it is open, fix the electric release and the mechcanical
release. The plastic clips break with age.
Streamlight Stylus Reach 18 Alkaline Battery-Powered Pen Light w/ Flexible Neck - at Test Equipment Depot
I had similar problem and went through the bottom right license plate hole with and offset straight blade screwdriver fumbling with it over toward the middle area where the latch is. It popped open. I also was leery of breaking the key when trying to use it in the key hole. After I opened it through the license plate I checked into the key hole more. I was only turning the key about an eighth of a turn before it felt like it would break, but it needs to go a full quarter of a turn to open the trunk. I wiggled the key around while turning and it finally did turn enough to open the trunk, It takes quite a bit of wiggling and slight in-out movement possibly. Much easier than license plate method.
First, I've read all the posts. I've got a 2004 XJ8... My problem is, the locking mechanism has a screw & lock-washer holding it secure... but through time it has come loose, forcing me to push harder on the trunk to close it... well, the last time I pushed down, I've got the latch stuck. I've tried the inside button and trunk button: I hear the 'click', but it doesn't open... The key has way too MUCH resistance... I wrapped a pry-bar in a towel and applied pressure under the trunk-lid while pushing the button, but no luck.
Has anybody had a problem like this?
JeffLear@BellSouth.net
Kyd
Kyd
sparkenzap (06-24-2014)
Open Trunk
I had same exact problem. I was able to open using the License plate method. But I also thought I was going to break something with the key. I found that you need to turn the key further than you think as it is a mechanical latch, I had to turn it real hard while wiggling in and out slightly and it turned far enough to open. Key needs to turn almost 180 degrees. I wish I had been more persistent with the key before I did the license plate method although it does work and got lucky and found the correct spot with the screwdriver fairly quick.
