Can't get wheel off.
Old 04-21-2012, 12:38 PM
avt007's Avatar
Default Can't get wheel off.
Well this is a first for me. I am trying to do front wheel bearings today, and the darned wheel won't budge. The nuts are off but repeated beatings with a dead blow hammer won't budge it. Ideas?
Old 04-21-2012, 01:16 PM
avt007's Avatar
penetrant, beatings, turning the steering on the ground, and even driving back forth in the driveway with loose wheel nuts and slamming on the brakes. Still no joy.
Old 04-21-2012, 02:10 PM
avt007's Avatar
Finally got it. drove down the street and it broke loose.
Charlie Smith (04-24-2012)
Old 04-21-2012, 02:15 PM
Received 8,106 Likes on 4,891 Posts
You might try to coat the hub center contact area with some anti-seize compound or grease to prevent the corrosion.
bob gauff
Old 04-21-2012, 02:33 PM
avt007's Avatar
I sure will. Just got the hub off, now to machine shop.
Old 04-22-2012, 10:22 PM
avt007's Avatar
3 out of 4 wheels gave me a hard time. All now have Never Seize on the centre hub. I also had to use a Dremel wire wheel to clean up the inside of the wheel so that it fit the hub without being forced.
Old 04-23-2012, 04:31 AM
steveinfrance's Avatar
And remember to torque them up to just 70 lb/ft - seems almost nothing.
H20boy
07-23-2021 09:39 PM
PMKimpton
08-03-2019 08:22 PM
abonano
25
09-25-2015 10:43 AM
Chuck Schexnayder
09-18-2015 03:10 PM
Jefro
09-15-2015 01:44 PM
Quick Reply: Can't get wheel off.
