can't pull the secondary tensioner help.
I opened the valve cover i saw tiny broken plastics between the camshaft chain . anyway I removed the 2 bolts that hold the tensioner which is 8mm bolts I tried to pull it in several ways but can't get it out so is there a way to do it without the pulling the exhaust camshaft?
i didn't continue the job because Im not sure what to do turning the harmonic balancer until the exhaust camshaft remove pressure on valves then pull it ?
2002 xj8.
2002 xj8.
Dutchy (05-28-2019)
thanks RJ
Received 2,675 Likes
Here is a link to the AJ Engine Course that includes the procedures and torque values:
https://www.dropbox.com/s/vqpy3bbjzd...e_168.pdf?dl=0
15FTypeR
03-25-2010 10:36 PM
