Can't See The Instruments: What's Up?
(this is a re-post from an incorrect forum)
OK, I wear prescription bifocal sunglasses, non-polarized. I can hardly make out the instruments on the '01 XJ during daylight. Since I usually run the edge of LE tolerance, I need to see the instruments.
I read the manual, but saw nothing about backlighting independent of having the headlamps on. I can't imagine I am the only one having this difficulty. So, what am I missing?
I also wear bifocals and sunglasses to the same prescription when required but never had issues viewing the Instrument Pack in daylight on my X308.
The bulbs do discolour badly with age reducing the brightness and it could be worth checking them. Unfortunately this does require removal of the IP.
Thanks, Graham...
I run side lights (led's) as DRL's or day time running lights, by happy coincidence this lights the instrument pack, with the dimmer clicked right over you should be able to see what you need...question, does it light fully at night, the instrument pack? if not you may need to replace some bulbs. 'How to's' on this job are numerous on this forum, and not as difficult as you'd imagine. Order new bulbs from the nearest Jaguar dealer, there are 8, you may as well replace the lot if carrying out the job.
I can't see mine either (in the daytime). The numbers are too small for my eyes, and something to do with the distance I am sitting from the cluster (I am 6'3" with LONG legs). My wife's 03 has MUCH bigger numbers, and I can see those without the problem. On my 98, I just memorized where 80mph is, and I can see the needle just fine. If I'm feeling lucky, I let it ride past 80 mark, if not, I am below.
IP Backlighting Normal At Night
Thanks...
