Car died while driving!!
Brian:
OK, a lot is "possible", but a vapor lock on a car with pressurized fuel (at 40 psi, no less!) AND a recirculating fuel circuit is not, in practical terms, possible. The lines are plastic and only so much heat can be transmitted through them before they melt. If the pump is hot enough to vaporize the fuel, I would name that condition "bad pimp" rather than "vapor lock"!
Brian:
You'll notice that I was very, very specific in my objection and agree (and still do) with your overall premise. Vapor lock is very seldom caused by a fuel pump, whether in-tank or exterior to it, not being able to pull liquid fuel. It is almost always caused by fuel vaporization upstream from the pump but prior to fuel delivery where it should go. It very, very seldom happens in pressurized fuel delivery systems like those used for fuel injection. It is, however, utterly incorrect to say that vapor lock is impossible for the exact reasons you stated, and I laid out exactly why.
The number of myths surrounding vapor lock, the biggest of which is that ethanol in fuel increases its likelihood, has put me on a self-appointed mission to correct the incorrect when I see it.
You're correct that this is likely to be something that isn't vapor lock.
BrentGardner
28
04-26-2024 04:08 AM
NinoGrimace
08-26-2015 06:15 AM
