Car feels down on power
Z07Brandon (09-14-2022)
Not any hotter than usual. But I'll double check.
Not sure how to check for clogged cats. Maf is new, Denso oem unit.
New pumps and fuel filter as of April 2020. But when I floor it, the instant mpg does go 4mpg, so I assume the secondary pump is working. But I'll make sure of it with a better test.
No clue how old the belt is. Stock pulleys, for now.
I'll have to see if that is the case.
All that said, I drove it once this week. Pulled great, like usual.
Spark plugs? Had an issue with feeling down on power and weird stumbling at mid throttle with no other faults for a long time, eventually traced it to spark plugs. Their gap was a little outside recommended, and they were slightly worn which made it worse. Replaced with new double iridium plugs with a gap slightly under factory spec (.052 spec for my year, think they measured a few thou narrower) and problem went away completely.
Z07Brandon (10-19-2022)
ExcelsiorZ
31
07-31-2018 10:10 AM
