Car over heating !!!
Old 07-01-2015 | 10:00 PM
san2slim38's Avatar
Default Car over heating !!!
I need help ! I own a 2001 Jaguar XJR Supercharge and my car is over heating. I have had the coolant hose, thermostat, water pump, and coolant tank replaced but my car is still over heating. the oil was checked and no mix, no white smoke coming from tail pipe to indicate a blown head gasket but my car will over heat after driving about ten minutes, I can let it run, turn ac unit on while the car is running(in park) and the temp gauge will display normal but soon as I drive the car after 10 minutes the gauge shoots all the way up. Lost and confused. can you help, thanks
Old 07-02-2015 | 02:02 AM
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
san2slim38 (07-02-2015)
Old 07-02-2015 | 02:25 AM
plums's Avatar
Look up the posts in this section about the proper orientation of
the bleed lines at the coolant expansion tank. Lots of people
install them so that they "look right". That is wrong. They should
be crossed. You'll understand once you see the pictures.
Old 07-02-2015 | 06:23 AM
san2slim38's Avatar
I cannot find the posts in this section about the proper orientation of
Old 07-02-2015 | 07:19 AM
test point's Avatar
fast40driver
04-19-2024 07:24 AM
1100me
08-27-2020 11:37 PM
Xj812
10-26-2015 05:04 AM
BlacXJRcat
09-08-2015 04:49 PM
Marque
08-27-2015 11:53 AM
Quick Reply: Car over heating !!!
