Car sat for two months now it wont fire
I installed a new battery and went to start it but it wont fire. I put a few drops of gas in the throttle body and it wants to fire. Fuel was low so I added a couple of gal of gas still nothing. Does the pump need to be primed? Two months ago it was fine. Ran no issues. I just needed to replace the battery. I live is So California and it snowed here once in December. Temp was around 30. The car was out in it. Could that have anything to do with it? How do I know the fuel pump is working? Can I check it as a one person? ![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
1998 XJ8L
1998 XJ8L
Received 12,943 Likes
I would throughly inspect the car for signs of unwanted visitors. Since it ran without trouble before, that is the most likely thing that could change it's running status.
Additionally, you could have a case where corrosion at a junction or connector has created too much resistance in the fuel pump circuit or some other key starting circuit.
To trace your wiring and circuits to locate any faults you might want to download the XJ Electrical Guide:
http://www.jagrepair.com/images/Auto.../jagxj1998.pdf
The New Fuels go Bad Quickly , I typically take that Shrader valve out put a 5/16 hose on it other end in can and if the pump is running , cycle it a few times to get fresh gas to there , put it back together ,cycle it a couple more times then start , I just bought one that had a bunch of old leaves and trash in the fuel fill area , drain was clogged and water stood in there and got around the filler cap , lots of water in the gas tank , ruined the pump and filter :-)
Although I do not want to fight the above as a possible cause, I myself have last year stored my car for several months at a time.
Just unplugged the battery, but always with a full tank.
Never any problem, starting at the first try.
Hope this helps you in eliminating possible causes.
Update: I hear the fuel pump prime and an initial click. I stuck a philips screw driver into the shrader valve and just get a dribble with the key on. I also hear a humming noise from the or near the throttle body. Oh and there is about 5 to 6 gal of gas in the tank. But I don't know of there is water on top. In the old days alcohol would remove or dissolve the water on top of the fuel. I think fuel additives have alcohol in them. Still need advice
Advice- worth every penny you are paying for it!
Get a fuel test gauge and test the fuel pressure. If good, use the gauge hose to run some fuel into a glass container so you can tell if it has water in it. If good pressure, and no water, then troubleshoot something else besides fuel delivery.
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
thedugger1
09-24-2015 05:32 PM
