car starting in first without speed button on
...remember without the speed button on the car starts in 2nd...any ideas? is this a TCM or Tranny mechanical problem
I am pretty sure that is an old wives tale promulgated here and elsewhere. You can count the shifts, or watch them on scanner software. You can read the Jag troubleshooting guide. QuadManiac is right. It just shifts sooner and feels softer.
FWIW--perhaps not much--my 2000 XJ8 manual says about gear selector positions:
D..Drive - All five gears are changed automatically as required
by the throttle position and road speed.
2, 3, 4..Second, third, fourth - if selected, the transmission
...........operates automatically but will not engage gears higher
...........than the one selected.
I wonder if a quick glance would imply that Drive cycles through 2, 3, 4, given the way the text is laid out and where the bolding is. (That's clearly NOT the meaning that's intended, though.)
Just a thought.
Just a thought.
I apologize - I believe you may be correct due to operation being different with the different transmission in the R - 2nd gear start when in normal mode, 1st when in sport.
I hadn't noticed you had an R and I was describing what the ZF tranny does in my XJ8.
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
Marque
08-27-2015 11:53 AM
