Car will not shift from Park....Help!!
Guest
Posts: n/a
Hi,
I have a 2000 XJ8 with 67k miles. First of all when i pressed the unlock switch on the key transmitter the car did not unlock. I changed the batteries and it still will not unlock or lock. I manually opened to door and when i started the car i tried to shift to drive and the car just simply will not shift from park. I called roadside assistance and they told me to unscrew the screw next to the park sign next to the shifter and once removed stick a pen down the opening and it did indeed shift but everytime i need to shift from park to drive i have to stick a pen in the shifter. Any thoughts on why this is happening. Please help.
Jagman2000
Jagman2000
I had the same problem with our 2001 XJ8 - I could not get the shifter out of park. 1st I thought that the brake light switch on the brake pedal might be the problem.
Then I also noticed that were a number of other things like the interior lights not coming on when I opened the driver's door and the garage door opener did not work. I also mentioned to my wife that there was something wrong with the windshield washers (since they were not working).
Check fuse# 7 (15 amp fuse) in the rear left hand fusebox - it controls "Body processor module (battery supply for solenoids, lamps and motors).
Sure enough it was that fuse that needed replacement and it fixed the problems.
Jim Lombardi
Jim Lombardi
BrentGardner
28
04-26-2024 03:08 AM
Isoruku
06-19-2020 12:54 PM
msdg137
09-16-2015 06:24 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
