Car won't go above 2,500 rpm
Old 01-10-2017, 03:33 PM
omgimali's Avatar
Originally Posted by JTsmks
If I read the thread correctly then something stands out. In "P" the revs should be "limited" IIRC to something like 2500/3000 RPM, yet you said yours revs fine in park past 2500/3000 (am I mistaken in that?) Yet won't go above 2500 in "D" It almost sounds like it's doing the opposite of what it's supposed to do.
in park it will rev to whatever you want, but in D it only does 2500 and thats hwy driving doing 70 plus, but in city it is 1500-2000 no more.
  #42
Old 01-10-2017, 03:34 PM
omgimali's Avatar
Had MAF cleaned month ago btw.
  #43
Old 01-10-2017, 03:45 PM
Received 2,263 Likes on 1,845 Posts
Originally Posted by omgimali
never tried it. if I do is it supposed to?
You should be able to hit the engine tachometer red line in each gear.
omgimali (01-10-2017)
  #44
Old 01-10-2017, 03:47 PM
omgimali's Avatar
Question
alright, so do I put it in sport?
  #45
Old 01-10-2017, 04:02 PM
No, use the left side of the J gate shifter to select the gears manually.
  #46
Old 01-10-2017, 05:15 PM
omgimali's Avatar
Imma do this tomorrow, need some fuel so I should do this on the hwy and do a hard acceleration.
  #47
Old 01-10-2017, 05:38 PM
GGG is offline
Received 16,861 Likes on 12,186 Posts
1. no DTC's set or pending
2. rough running when cold
3. revs OK in P but not under load in D
Restricted fuel pressure is looking increasingly likely.
  #48
Old 01-10-2017, 06:12 PM
omgimali's Avatar
Question
I have not changed the Fuel Filter on this car yet. Do you think this could be the cause?
  #49
Old 01-10-2017, 07:00 PM
RJ237's Avatar
Received 2,806 Likes on 2,239 Posts
You should not be able to rev over 3000 in neutral or park, I'm beginning suspect a ECU problem.
  #50
Old 01-10-2017, 07:26 PM
JTsmks's Avatar
Than you RJ, I was trying to point that out a few posts ago. These engines should not rev in Park and his is which is the biggest clue.
  #51
Old 01-10-2017, 07:50 PM
omgimali's Avatar
the N/A XJ8's don't have a rev limiter. I can rev to 3000RPM but in drive it doesnt go above 2500. Thats what I am trying to say, it doesnt sputter or cough it just changes gear if you get close to 2500 rpm. Tomorrow I should try the Manual J-Gate selector.
(couple days ago at walmart I started the car and it had Restricted Performance and CEL - misfire #7 - I revved it and wouldnt go above 3000rpm it would just shake the car. a rough idle.)
  #52
Old 01-11-2017, 01:51 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Fix that fault. Until you do it's putting unburned fuel/air into the cat and causing damage.
omgimali (01-11-2017)
  #53
Old 01-11-2017, 05:18 AM
JTsmks's Avatar
May be a stretch but when's the last time the cars had the fuel filter changed?
  #54
Old 01-11-2017, 02:42 PM
omgimali's Avatar
Exclamation
never been changed
  #55
Old 01-11-2017, 03:29 PM
RJ237's Avatar
If the filter were the problem it wouldn't accelerate, would probably backfire due to starvation. But the filter probably does need changing.
  #56
Old 01-11-2017, 06:27 PM
omgimali's Avatar
ok, i should replace the filter.
