Car won't take gas
Went this AM to put gas in car. As I was trying to pump the gas, the gas nozzel kept clicking off as to indicate it was full when actually there was no gas in the tank to speak of, Vapor Lock??? Check engine light is on but don't have a scanner to check. any suggestions????
my car does that sometimes, I have found if you don't shove the nozzle all the way into the car, and just barely insert it, there is no problem filling it up.
as far as the code I suppose it could be related, you can use the codescanner at advance auto for free, you give them your driver's license and they give you the scanner, or sometimes they just walk out to your car with you (there have been problems with people stealing the scanners)
good luck
I'm from the 757 as well, you don't see too many XJ's in our area
good luck
Sshenton1975
08-30-2015 09:29 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
