Cats rear shock bushes
Received 1,813 Likes
Here's a thread with an exploded view..... https://www.jaguarforums.com/forum/x...4/#post1873271 ....and yes you can replace them. As stated in that thread, be sure to do the dampers also. Do a Search and you'll get plenty of threads to review.
Good advice. If you carefully remove the rubber dust covers you should be able to find a socket that fits over the inner shaft and rests on the outer race. You will also see the inner shaft is pressed into the bushing from one end, that is the end you want to push against when installing as the outer race on the other end has a beveled edge to aid installation. This probably doesn't make much sense, but it will when you look at a new bushing.
p-Rock
09-04-2017 03:36 AM
wackymatt
16
09-15-2013 05:42 PM
H20boy
General Tech Help
10-31-2010 08:27 PM
